    single supra vs gallardo superleggra auf der rennstrecke | Forum
    Spoony
    www.youtube.com/watch?v=kzyMNfqaVg8&feature=channel_page
    hier isser auch nochmal in 8:15 um die nordschleife
    www.youtube.com/watch?v=pimMAmznE3c
    hier die specs:
    Thanks for all the positive replies guys, i expected at least 1 or 2 wiseguys to say "the lambo driver wasn`t trying" ,
    To answer a few questions,
    Spec is phr2+ turbo running 520fwhp @1.4bar, was running 1.3 on the lambo session so around 500hp,
    Nothing special in the suspension department, kyb agx dampers on j-spec springs with a decent geo setup.
    I will update my garage and list everything else ive done.
    When you say stripped out ive only changed my front seats and took out the backs but ive fitted a cage which must put the weight back in, i was running 1,3 bar so around 500fwhp (flywheelhorsepower, also motorleistung!!!).
    zu den bremsen:
    I am surprised the uks perform that well, you seemed to be out braking him most of the time, probably more to do with your driving technique though I guess..?
    The brakes were strong all day.
    also normale eu spec bremsen, beide sitze vorne getausch und die rückbank raus in punkto gewichtsersparniss
    naja, nur schnell gradeaus so ne supra, ne :grinning:
