    Ein weiterer Supra aus der Türkei | Forum
    ReDLineMKIV Owner
    http://www.yukleresim.com/images/68956867867342708347.jpg
    http://www.yukleresim.com/images/99507074865461357402.jpg
    http://www.yukleresim.com/images/55656603213281541957.jpg
    http://www.yukleresim.com/images/81806993243361505448.jpg
    http://www.yukleresim.com/images/38202681983835887054.jpg
    http://www.yukleresim.com/images/62251587906013344691.jpg
    http://www.yukleresim.com/images/38735986197549833272.jpg
    http://www.yukleresim.com/images/00245145451690731357.jpg
    http://www.yukleresim.com/images/73438326618128034534.jpg
    http://www.yukleresim.com/images/72786199256199311632.jpg
    http://www.yukleresim.com/images/77320329154890336544.jpg
    http://www.yukleresim.com/images/27953805997345144459.jpg
    http://www.yukleresim.com/images/67719769665051451671.jpg
    http://www.yukleresim.com/images/80854863110964881453.jpg
    http://www.yukleresim.com/images/17163117382972020422.jpg
    http://www.yukleresim.com/images/76397179609393077049.jpg
    http://www.yukleresim.com/images/76613341656206177996.jpg
    Und der erste Start nach der Fertigstellung...
    www.streetfire.net/video/supra-first-start-sup40_2059398.htm
    Motoraufbau und Einzelanfertigungen etc von Peak Garage
    AEM Programmierung von OZ ECU(der dickerchen im Video:grinning:)
    Ein Auszug aus der Teileliste
    -Titan billet main caps
    -ARP main studs
    -Carillo H beam kollar
    -Titan motorsports Custom piston set
    -ARP 1/2" bolts
    -Power enterprise Rod bearings
    -Boostlogic Headgasket
    -Ferrea Competition Plus Valves
    -Ferrea Valve Springs
    -Ferrea Titanium Retainers
    -Ferrea Spring Seat Locator
    -Ferrea Valve Locks
    -Ferrea Valve Stems Seals
    -HKS Cam Gears
    -HKS 264 Camshafts
    -HKS Timing Belt
    -Titan Motorsports Billet Timing Belt Tensioner
    -Greddy Pulley Set
    -Greddy Ansaugbrücke
    -Hypertune 90mm Drosselklappe
    -Fullrace turbo manifold
    -Garrett bb gt4094 t4 divided turbo. ( nach der auto2manual swap soll es auf gt42 od 45 gehen)
    -Boostlogic Supra TT Oil Feed and Return Kit
    -Titan motorsports triple fuel pump system
    -HKS oil cooler
    -HKS hypermax coilover set
    -AEM Water Methanol Injection Kit - 5 GAL
    -Boost Logic Torque Converter by 3800 Stall
    -Spal 7.5" Pull Fan For Auxillary Cooler
    -9 Passage Transmission Oil Cooler 18x8.75x1
    -R2 Racing Front Control Arm Bushing Kit
    -R2 Racing Rear Control Arm Bushing Kit
    -Samco Hose Kit
    -TRD Low Temp Thermostat
    -Koyo Radiator 53mm
    -AEM 5 Bar Map Sensor
    -AEM Intake Temp Sensor
    -AEM EMS Gen 2 Ecu
    -AEM Wideband
    -HKS DLI
    -HKS Radiator Cap
    -MVP Motorsports Lexan Spark Plug Cover
    -TRD Motor Mounts
    -TRD Oil Filter Cap
    -TRD 10,000 RPM Tach
    -TRD 320 km/h Speedometer
    -TRD LSD w/Installation kit and all Bearings need
