    Blitz MK4 auf dem Nürburgring | Forum
    Amtrack
    Habe in der Suche nichts entsprechendes gefunden, ich hoffe es war nicht schon einmal da.
    www.dpccars.com/car-movies/07-03-06pageBlitzToyotaSupraatNurburgring.htm[/url]
    und ein paar Daten zum Wagen
    eepSkyBlue">BLITZ TOYOTA SUPRA TURBO SPECIFICATIONS
    Engine:
    3068cc straight 6-cylinder, 24 valve, twin-cam, twin-turbocharged, 1.8mm metal head gasket, Kolben Schmidt pistons, H-section conrods, balanced crank, Blitz Access engine management system, lightweight racing battery, NGK no 10 racing plugs, valves and ports polished, KKK K26 turbos, Blitz-type RC wastegates, Blitz B-type intercooler, A-type Oil cooler and power steering cooler, Blitz prototype radiator, twin Bosch 240-litre fuel pumps, NISMO (Nissan Motorsport) single 2.7kg/cm squared fuel regulator, Blitz 850cc side-feed injectors. Racelogic traction and launch control, Blitz 42.7mm stainless manifold, 60mm twin- tube and 100mm Silencer with 130mm outlet.
    Transmission:
    Getrag 6 speed gearbox, triple plate clutch with lightened flywheel, Blitz prototype diff cooler, final gear ratio 3.588, TRD (Toyota Racing Development) transmission bushes.
    Suspension:
    Front - double wishbone with Sachs two-way damper and Eibach co-axial spring (rated - 18kg)
    Rear - double wishbone with Sachs two-way damper and Eibach co-axial spring (rated - 12kg)
    Toyota original anti-roll bar, TRD rear subframe bushes, Blitz prototype top mounts.
    Brakes:
    Front - Brembo Ferrari F0 setup consisting of ventilated 332mm discs (35mm thick)
    Rear - Toyota standard 320mm discs (28mm thick)
    PFC carbon metric pads all round.
    Wheels and Tyres:
    Front - Blitz Z-1 9x18" split-rims with 245/40 ZR Dunlop W-10 tyres
    Rear - Blitz Z-1 10x18" split-rims with 265/35 ZR Dunlop W-10 tyres
    Bodywork:
    Blitz front/rear bumpers, side skirts, adjustable rear wing and lightweight doors, TRD vented bonnet.
    Interior:
    Stripped out with Blitz-Konig RS-2000 carbon/kevlar buckets, Sabelt harnesses, Heigo 4 point rollcage with side bars, TRD steering wheel, additional boost, oil and water temperature gauges (all Blitz).
    Performance:
    Max Power - 750bhp at 5900rpm
    Max speed is 200+mph
    0-60mph in under 4 secs
    0-125mph in under 10 secs.
